-   -   Fender trimming help (https://blazerforum.com/forum/paint-body-interior-39/fender-trimming-help-79225/)
lityjohn701 May 12, 2013 07:34 PM
Ok got a couple of questions here. My passengers side fender on my blazer is bad so I pick up one off a zr2 s10 same color. I got all four flares. I know I've heard the s10 flares won't fit on the back but they will. My question is my tires rib because I have a 0 offset. 8 inch wide rims with 31s. How should I got about cutting the zr2 fender so it doesn't rub anymore? Does anyone have any pics of someone doing this? Should I cut the flares so they don't rub? Or if I cut the fender will the flare shape to it? Thanks.
lityjohn701 May 14, 2013 08:48 AM
Bump. All I need to know is how should you go about trimming the fender and the flare
El_Beautor May 14, 2013 09:16 AM
Jamaroon shares this awesome link a lot. It's from the S10 Crew Cab site. Skidz Cut-Out Flares. It's a great walk through on trimming your fenders.
Jamaroon May 14, 2013 01:35 PM
That's only for no flares, with ZR2 flares you have to cut the flare. Trim a bit, test fit trim some more. Repeat until no more rubbing.
lityjohn701 May 15, 2013 07:27 AM
Where do I cut the flare
Jamaroon May 16, 2013 11:57 AM
Wherever the tire touches it...
lityjohn701 May 16, 2013 07:39 PM
Very helpful...
Jamaroon May 16, 2013 09:28 PM
I don't know what else you want, it's not difficult to figure out. There's no one answer on where or how much to cut. It'll be different for almost every truck out there.
Install everything, see where it rubs and cut. That's the best advice you will get.
rexmburns May 16, 2013 10:02 PM
^x2 there's is no exact spot to cut besides where your tires are hitting. Like jam said all trucks are different.
