fix holes in hard tonneau cover ?
hi,
i bought a used tonneau cover for my 88 s-10, the previous owner installed a wing on it... :icon_doh: i want to remove the wing and patch the holes. the cover is fiberglass. anyone knows how i should do it properly ? the cover will be repainted so i want to do it right once. thanks ! |
sand down around the area you want to fill, and get some bondo-glass (the bondo with fiberglass strands in it, first take some, and pack it in the hole until they are full, and then smooth it out, sand it down, use a good primer over it, you should be good.
allright thanks, ill try that.
| All times are GMT -5. The time now is 02:55 PM. |
