front grille swap
im very new to blazers and im thinking about purchasing a 92 4door 4x4 but i want top know if i can convert the front grille to the longer 4 light front which seems to be stock on the 2door full size version. Does anyone know what im talking about? Please learn me something. LOL. Im goin to try and add photos of what im asking about.
RE: front grille swap
these are what im talking about
[IMG]local://upfiles/9679/B07B413212BD4ADA9BD1B3D9D7E7A9D4.jpg[/IMG] [IMG]local://upfiles/9679/33B0D64D3A4D45F2BF1272B3A118C290.jpg[/IMG] |
I know on a 94 to a 2000 frend end swap you need to change radiator supports so the headlights fit. I'm pretty sure that everything hooks right up to the radiator support (headlights, grille). I would imagins that yours would be the same thing. Check the length of the radiator support and see if they are the same length.Some modding would probably be involved. Someone correct me if I'm wrong. Do a little searching around all the chevy forums to see if you could find something.
Isn't there a significant size difference from the 4 light grille on the full size chevys, and the s series grille? There would have to be an s series (truck or suv) that had the 4 bar set up at one point and time, or else it will require a wholleeee lot of 'modification' (read fabrication).
ORIGINAL: WolfPack Isn't there a significant size difference from the 4 light grille on the full size chevys, and the s series grille? There would have to be an s series (truck or suv) that had the 4 bar set up at one point and time, or else it will require a wholleeee lot of 'modification' (read fabrication). there is a BIG difference |
but it has been done. i dont remember which site it was but i know i have seen one before...
Found one.
http://www.streetsourcemag.com/uploa...045PM77591.jpg Check out S-10 Forum's thread on S10 Conversions here |
thats it! although, i think i may have seen another one around also
This one looks a little cleaner...the grille does anyway..
The red one looks like he custom made the grille, this one looks like it might actually be from a full size chevy! http://www.streetsourcemag.com/uploa...031PM60731.jpg |
| All times are GMT -5. The time now is 11:31 PM. |
