Frontend change
I have a 1996 Blazer and it has really bad / small front lights. What do i need to change if i want to put on 97 or newer lights ?
What years did the lights in the front change ? |
1998 they changed. you looking to change it to my front end right? I'm pretty sure they make a kit for it but you'll need the headlights, bumper lights, grill, bumper and new radiator mounts. I'm not 100% sure if the actual light bulb sizes are different or not. in the end you are probably looking at spending at least $200 depending on if you get the parts new or used.
Just do a search, bro. This has been discussed many times.
Did search but couldt find what i was looking for :(
1996 had the small front lights, when did they change to bigger ones and when did they change to the ones with 2 in the front ? |
The Composite lights were an option on the 4 door since 1995. You have the sealed beam lights.
The front end like mine(shown in sig) came out in 1998. |
Oh ok.
The 1998 front is the one i was thinking of. Are there kits to buy to convert to that front or ? Also what parts do i need to change ? |
google is your friend http://www.google.ca/#hl=en&source=h...ad2a9a3503d34a
You'll need to change:
obvious stuff -grille -headlights -signal lights -bumper -valence (plastic part under bumper) -all the fasteners not so obvious stuff -rad core support -bumper brackets (IIRC) You have to be careful because your Core support can either be bolted on (like my 05) or be welded in, which then becomes a real PITA I suggest you look here: http://chevroletforum.com/forum/showthread.php?t=14500 |
[quote=oktain;311980
You have to be careful because your Core support can either be bolted on (like my 05) or be welded in, which then becomes a real PITA [/quote] I've seen this in a few threads on this topic now. What is the split between Blazers that have a welded in and bolted in support? Was it split by model years? Assembly plant? |
No clue... I found that in my research and no year span was found... it could be "plant" dependent too...
| All times are GMT -5. The time now is 02:51 PM. |
