-   -   Gauge cluster lights (https://blazerforum.com/forum/paint-body-interior-39/gauge-cluster-lights-75273/)
99Legendary 11-20-2012 11:49 AM
This may be a stupid question.
superbrightleds.com changed their site layout around a little bit and I am some what confused on what I am getting.
I know I need "twist lock" bulbs for my gauge cluster like Thogert says, but I am unsure which ones they are.
(I AM GUESSING THEY ARE THESE?)
NEOx LED Bulb - Instrument Panel LED | Instrument Cluster and Gauge | LED Car Bulbs | Super Bright LEDs
Also, here is the main page for cluster lights. Thanks guys
50lb_cat 11-20-2012 01:33 PM
From what I understand, you need the twist lock base and T10 bulbs, and you buy the base seperate from the bulbs. Someone correct me if im wrong, as I have been debating on doing the LED swap as well.
Thogert 11-20-2012 02:39 PM
Yep, you need the T10 (called 168/194 on the site) bulbs and the bases to match.
Here is the kind of bulbs that are most popular for the gauges.
Here is the matching bases.
50lb_cat 11-20-2012 02:47 PM
Not to hijack, but what do you recommend for the overhead and floor lights thogert, thanks again!
99Legendary 11-20-2012 10:01 PM
Floor lights are 194 and overheads are 44mm
Thogert 11-21-2012 12:39 AM
^Yep (although I wired in a custom setup on my roof lights.)
CanadianaBlazer 10-28-2013 02:28 AM
Buying red LEDs for cluster ... how many do I need to buy? (including climate control cluster, 4x4 buttons, headlight switch panel, power window/lock switches, etc.)
Thogert 10-28-2013 10:21 AM
Check the link in my sig.
