GM Step bars
I just bought some (used) GM step bars for my 2005 blazer. I figured out that the front is mounted using the body mounting bolts. Now can anyone tell me if you use the stock bolts or did these come with a longer body mount bolt? Is there a washer that is mounted between the step bar and the bolt? I'm just wondering if I'm missing any hardware that I have to track down.
I have alsdo figured out the the parking brake cable is threaded through the rear bracket and the bracket has the u-bolt that is somehow threaded through the frame. Am I on the right track here? I really wish I had some pictures to help me out with this. I'd post pictures of the step bars but Photobucket is doing weird things tonight and I cant access or upload pics right now. |
I got the pictures of the step bars now:
http://i219.photobucket.com/albums/c...Blazer/006.jpg http://i219.photobucket.com/albums/c...Blazer/007.jpg Ignore the broken mount on the one step, I've already had it welded. I tried to mount them up this afternoon but I have discouvered thet the stock body mount bolts are 1/2" (10mm) too short so I'll have to find new ones. while I was under the truck I checked the mounting for the rear. This I am completly stumped on. I can't find anything that the u-bolt on the rear will fit into unless they expect me to drill holes into the frame. Anyone got Ideas? |
Silly question but uh, are you sure you have L & R on the proper side?
I've never mounted nerf bars or anything of the like but if you have to drill holes, I say drill them. By the looks of them the tube end fits into a place in the frame I'd assume & the other bracketed end mounts on something higher & because of the reach of the extra brackets, would they mount behind the frame ot into it? Like I said, never mounted them before, just looking & offering 'outside' ideas. |
After a bit more studying of the bars I have figured out how they go. Rottidog, you are right. I will have to drill one hole on each side. There is a pre-existing 1" hole for the one side of the u-bolt, and I'll have to drill the other. I also ordered 2 new body mound bolts and they should be here in a few days. The originals are 85mm long and my new ones are 100mm long (stronger grade too) .
I'll post pics when it's installed. |
| All times are GMT -5. The time now is 05:57 PM. |
