Halos GMC Jimmy
I was wondering if anyone has either A.) Found projectors for a jimmy or B.) Found projectors that will work with a slight bit of modification. I love the look of projectors but can't seem to find them anywhere. I have a 98 jimmy btw
if you get some cheap ebay housings (with a clear lens) hit up The Retrofit Source online: headlight upgrades for all applications you can get projectors, and bulbs/ballats that fit it real well. Very good site, and reliable, with amazing customer service. HiDplanet : The Official Automotive Lighting Forum will also help you if you have any questions about the retrofit, worth the time and money IMO.
Good luck! |
Unfortunatley You will have to retro fit projectors in as they are not made for the jimmy/bravada. I ran into the same issue with my 97 bravada. I have vacuum formed clear lenses and am in the process of retro fitting a set of projectors in.
isn't retro fitting pretty expensive
It can be, yes.
what exactly is retro fitting
Pretty much taking the projectors from a bmw/mercedes ect and fitting them to your factory headlight housing.
These are off a tsx http://i463.photobucket.com/albums/q...IMG_6950_1.jpg |
Originally Posted by Unlimitedsp
(Post 537806)
Correct. Clear lenses are a must. Once i finish my new vacuum forming table. I should be able to make clear lenses for pretty much anything.
haha way to difficult for me. I'll just sick with my HIDS and call it good
| All times are GMT -5. The time now is 08:29 AM. |
