Headlights
I have a 1997 blazer with the sealed beam headlights I am wondering if I can use these headlights.
http://cgi.ebay.com/ebaymotors/ws/eB...3438%26fvi%3D1 I am new to this modifications thing so any help will be greatly appreciated. |
RE: Headlights
if that looks like urs then it should as the years are the same. then I'd say yes.
RE: Headlights
i have the two piece lights where the headlights are square and the corner lights are seperate
RE: Headlights
hmmm Try and find the ones that are split up. Lol sorry bout that!
RE: Headlights
if you have the sealed beam headlights like i do, then no you cant use them
kind of funny, i almost bid on these on ebay, actually sent you a message if youre the seller. are you still trying to sell these? I'm interested in buying them for a composite headlight swap |
RE: Headlights
hi, welcome. Im new to this forum and mod thing too! i also have a 97 blazer w/composite headlights and yes those are correct lights for the truck. im actually looking to buy the same type of headlights aswell-they ll look great on. just make sure they say they are for composite headlights only. Good luck
RE: Headlights
I have these composite headlights for my Blazer and they do look awesome. If you have the sealed beam headlights, technically YES you could use them, assuming that the radiator support is the same BUT...BUT you'd have to modify the wiring because you'd now have 2 bulbs (low and high beams separate) and you'd also have to replace your grille because the grille is completely different. If someone can convert a 95-97 to a 1998 and up, it shouldn't be very hard to convert your sealed beams to composites...Good Luck!
| All times are GMT -5. The time now is 05:50 PM. |
