-   -   Holes in the roof (https://blazerforum.com/forum/paint-body-interior-39/holes-roof-72593/)
rockNnachos 07-27-2012 08:21 AM
Holes in the roof
I just purchased an 02, 2 door 4x4 that belonged to the county. Looks like they had mounted antennas to the roof as I have a 3/4" hole and a 1" hole up there. Anyone know an easy way to plug them? Thanks in advance!
Coddrick 07-27-2012 04:44 PM
Honestly, I would probably just fill them in with bondo. It seems a little too small to think about welding patches over them, and shouldn't crack under the flex of the roof. I'm sure someone else has a better idea, that I never in a million years would have thought to do, but as for cheap-fast-and easy, I would go with bondo.
redneck44244 07-27-2012 05:00 PM
you maybe able to find a 3/4 and 1 inch body plug at any place that sells auto body parts and supplys and then silicone them in place to make them water tight. quickest and easiest way i can think of.
rockNnachos 07-28-2012 06:46 AM
Thanks for the replies/ideas!
Im goin this direction first, it sounded easier. Googlin' rubber plugs, body plugs, grommets, etc and I found these on eBay. RUBBER BLANKING GROMMETS
Think I'll give em a whirl.
redneck44244 07-29-2012 11:10 AM
ya i had the same problem with my blazer the owner before me had drilled a 1 hole in the floor for who knows what and thats what i did since im no autobody guy.:icon_couchhide:
richphotos 07-29-2012 01:20 PM
Bondo will eventually crack, the previous owner removed the tire rack on my jimmy and filled the holes with bondo, and it has cracked.
84BlazerS10 07-29-2012 06:52 PM
I took my roof rack off mine but I welded up the holes don't really know of any other ways of doing it without having it leak or something later on.
swervinblazer88 11-29-2012 04:58 PM
when i removed my roof rack i used blue vinyl tape
richphotos 11-29-2012 05:14 PM
I guess that is one way to do it :icon_rain:
neo71665 11-29-2012 09:18 PM
Bondo in a hole in the roof will pop out in 2 weeks if daily driven. If parked outside right now in the winter even sooner.
Rubber plugs and silicone is your best bet besides welding the holes up.
