How-To: Install Glow Gauges
Old Dec 13, 2009 | 07:00 PM
  #31
David Reeves's Avatar
David Reeves is on a distinguished road
Question. I noticed in your second paragraph you said to write down the positions of all the gauges while the truck is switched on. In the first paragraph you said to disconnect the wiring harness. Are you sure step one is before step two? Please explain. I intend to change my gauges to a white face and this interests me very much.
Thanks,
Dave R
Old Dec 14, 2009 | 10:31 AM
  #32
warthogdriver's Avatar
having done this myself.
you need to check gauge positions before disconnecting gauge cluster.
Old Dec 31, 2009 | 10:44 PM
  #33
davtak's Avatar
doh! thanks for pointing that out. you will want to write down the needle position with the truck in accesory before you unplug the harness. I'll go back and fix that, thanks for pointing it out.
just checked it out and the harnesses i am talking about in the first paragaraph are the headlight harness, the rear wiper and rear hatch, and the 4wd harness (if applicable). that is just to get the dashboard surround off to get to the gauge cluster. then write down the needle positons, and then unplug the gauge cluster and go from there.
Old Feb 4, 2010 | 07:04 PM
  #34
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
pics are dead
Old Mar 29, 2010 | 11:33 AM
  #35
blazed16's Avatar
blazed16 is on a distinguished road
bringing old threads back from the dead haha so great...
Anyways i bought some of these gauges looks exactly the same now i just need to install them...
So i just turn the truck to assessory but do not start it correct?
And then put it all back together and turn truck to assessory and push needles back to where they were before correct
Old Apr 14, 2010 | 01:31 PM
  #36
blazed16's Avatar
Someone gonna answer the above question please^^^^ i want to get these installed this weekend hopefully
Old Apr 14, 2010 | 01:35 PM
  #37
Key to 'run', running or not it does not matter. This is covered in many a gauge install review on the net as well as stated in the first post above...
Old Nov 10, 2010 | 03:49 PM
  #38
JeremyG's Avatar
JeremyG is on a distinguished road
Ok, so I'm looking, where do I even FIND these gauges, for an 84 K5?
Old Sep 23, 2011 | 10:34 PM
  #39
gatorboy44's Avatar
gatorboy44 is on a distinguished road
The pics don't show up?
Old Nov 27, 2011 | 08:36 PM
  #40
bobby099's Avatar
bobby099 is on a distinguished road
Post glow gauge problem
hi i just installed the glow gauges in my blazer but the only problem i have no is my cluster sticks all of the gauges dont seem to work. i thought maybe i could just unhook the battery and reset it but no. could you tell me if i might need to send it in or maybe someone could help me out thanks.
