-   -   How-To: Install Glow Gauges (https://blazerforum.com/forum/paint-body-interior-39/how-install-glow-gauges-11642/)
David Reeves Dec 13, 2009 07:00 PM
Question. I noticed in your second paragraph you said to write down the positions of all the gauges while the truck is switched on. In the first paragraph you said to disconnect the wiring harness. Are you sure step one is before step two? Please explain. I intend to change my gauges to a white face and this interests me very much.
Thanks,
Dave R
warthogdriver Dec 14, 2009 10:31 AM
having done this myself.
you need to check gauge positions before disconnecting gauge cluster.
davtak Dec 31, 2009 10:44 PM
doh! thanks for pointing that out. you will want to write down the needle position with the truck in accesory before you unplug the harness. I'll go back and fix that, thanks for pointing it out.
just checked it out and the harnesses i am talking about in the first paragaraph are the headlight harness, the rear wiper and rear hatch, and the 4wd harness (if applicable). that is just to get the dashboard surround off to get to the gauge cluster. then write down the needle positons, and then unplug the gauge cluster and go from there.
Spectreblazer Feb 4, 2010 07:04 PM
pics are dead
blazed16 Mar 29, 2010 11:33 AM
bringing old threads back from the dead haha so great...
Anyways i bought some of these gauges looks exactly the same now i just need to install them...
So i just turn the truck to assessory but do not start it correct?
And then put it all back together and turn truck to assessory and push needles back to where they were before correct
blazed16 Apr 14, 2010 01:31 PM
Someone gonna answer the above question please^^^^ i want to get these installed this weekend hopefully
swartlkk Apr 14, 2010 01:35 PM
Key to 'run', running or not it does not matter. This is covered in many a gauge install review on the net as well as stated in the first post above...
JeremyG Nov 10, 2010 03:49 PM
Ok, so I'm looking, where do I even FIND these gauges, for an 84 K5?
gatorboy44 Sep 23, 2011 10:34 PM
The pics don't show up?
bobby099 Nov 27, 2011 08:36 PM
glow gauge problem
hi i just installed the glow gauges in my blazer but the only problem i have no is my cluster sticks all of the gauges dont seem to work. i thought maybe i could just unhook the battery and reset it but no. could you tell me if i might need to send it in or maybe someone could help me out thanks.
