Install corner side marker lights
I am looking to install euro clear corner side markers in a 1997 blazer ls. The entire thing seems sealed and I can't figure it out. Please help me if you know how to put in after market corner lights.
RE: Install corner side marker lights
if you look in the corner nearest the headlight, there are two small torx screws there. actually in the cavity of the headlight. thats it.
Sorry no such thing on my Blazer. I really think I have a really weird set up. I have a 97 with the composite headlights and I can't get the front lens off. The front lens has 4 metal clips in each corner, I took them off and still nothing. No screws or anything I can see. There is a type of stick sealer but I dont want to rip it up if I dont have to. So if you have anything else please let me know if not thanks anyways.
square headlights?????
They arn't the square type, not the sealed beems I have 2 composite bulbs inside. There is a protective plastic lens covering the side marker lens as well as the composit bulbs inside. They are not the sealed glass bulbs. If you look up a 1997 Blazer LS you might be able to see what I am talking about. Thanks for you time and effort.
just saying that I have a 97 blazer LS. I have square headlights. check my photo gallery.
If I could figure out how to post pictures I could show you. I have the composite headlights. I really think they are sealed beams or something. They are rounded off,If you go on ebay and look up the 97 Blazer LS they are on there. Try http://cgi.ebay.com/ebaymotors/Chevr...86288343QQrdZ1
Your blazer is like mine, and you CAN NOT seperate the front side-marker lights from the headlight assembly (at least without destroying it). You bought lights for one like hillbilly's and you CAN'T use them on yours.
THANK YOU!
If its like mine you just have to jerk really hard on the grille to pull out the slide-in pins then jus take the lenses off and replace.
