Interceptor OBD2 Gauge - Chevy Blazer late 1995
Old Jun 7, 2009 | 12:37 PM
Denominator's Avatar
Denominator is on a distinguished road
Default Interceptor OBD2 Gauge - Chevy Blazer late 1995
My Chevy Blazer LT is as stated earlier an late year 1995.
But it has the full OBD2 setup. Will that allow me to install the interceptor OBD2 Gauge? If so, what sensors and functions will it read on this blazer?
The list on their webpage:
  • RPM
  • MPH
  • Intake Air Temperature (post Intercooler)
  • Ambient Air Temperature (pre Intercooler)
  • Engine Coolant Temperature
  • Exhaust Gas Temperature (PCM Calculated)
  • Transmission Temp. (auto trans)
  • Manifold Pressure (vacuum/boost) displayed in PSI
  • Fuel Temperature
  • Battery Voltage
  • Battery Temp
  • Injector Pulse Width in msec.
  • Injector Duty Cycle (%)
  • Air Flow Rate into engine
  • Long Term Fuel Trim
  • Short Term Fuel Trim
  • O2 Sensor Voltage
  • Barometric Pressure
  • Ignition Advance
  • Base Spark
  • PCM Spark Adjust
  • Fuel Status (open/closed loop)
  • Wastegate Solenoid Duty Cycle (%)
  • Knock Retard
  • Knock Sensor Raw Voltage
  • Throttle Position Percentage
  • Throttle Position Sensor Raw Volts
  • Calculated Net Horsepower
  • Engine Load
  • Transmission Slip
  • Current Transmission Gear
  • Torque Delivered to Transmission
  • Torque Converter lockup status
  • Brake pressure
  • Brake Booster Travel
  • Steering Angle
  • Non-driven Wheel Speed
  • Lateral G's
  • Yaw
  • Fuel economy (instantaneous and average)
  • P-ratio - pressure ratio MAP/Barometer
  • 2 user configurable analog inputs**
THX Guys!
Old Jun 7, 2009 | 02:25 PM
Biohazed's Avatar
if it is full OBDII then the interceptor will work fine
Old Jun 7, 2009 | 07:21 PM
midnightmekanik's Avatar
midnightmekanik is on a distinguished road
I'm actually interested in this... Does the obd2 on the blazers show trans temp? Other trans related info? I'm thinking it will be nice to see when I'm towing the boat...
Old Jun 8, 2009 | 01:45 PM
I don't think it will do that without an extra temp sensor. But the interceptor has 2 user configurable analog inputs.
Old Jun 8, 2009 | 03:53 PM
ABN31B's Avatar
Arrow
Well I was going to say that thing sounds stupid until I saw the
Originally Posted by Denominator
[*]Knock Retard
Now I NEED one! Do you have a link to this bad boy? I know that sounds sarcastic, but I am honestly interested in checking this thing out.
Old Jun 8, 2009 | 04:05 PM
Old Jun 8, 2009 | 08:02 PM
Biohazed's Avatar
I know alor of people on the Bonneville forums use them and have nothing bad to say about them at all
Old Jun 12, 2009 | 11:21 AM
INHUMAN's Avatar
INHUMAN is on a distinguished road
I have the double set up in my camaro. they are cool. i dont know if it was worth the money or not. i use it for knock retard as a supplement to my wideband guage when im spraying the juice to it. they come in different color combos etc.....
70Camaroman
Feb 24, 2012 06:00 PM
PhilX
Oct 4, 2010 02:13 AM
ashmarie321
Jul 13, 2010 01:15 AM
maverick11
Mar 5, 2009 09:46 AM
Hoelgi
Oct 11, 2007 02:37 PM
