lower side plastics
on some zr2s ive seen a black plastic strip on the lower sides connecting the wheel weld plastics and looking like one solid plastic piece.my questions are is this something from chevy stock on some models?and do i get the side moldings from dealer or somewhere else?any help will do you guys are always great .thanks
Are you talking about the fender flares? All ZR2's came with them. If you aren't talking about fender flares, I have not idea what you are talking about, sorry.
lower side plastics -?
im talking about the lower sides from front fender flare to the rear fender flares on both sides.basically its a black molding that makes the fender flares appear to be one piece .it runs across the whole lower door from the section where the body ridges out .the part that has the blazer emblem on the side.so the whole lower door section plus a little on rear and front lower sides.its function would be to protect the whole lower sides of the door in between each fender flare.i hope this helps i dont have a pic but after researching i saw many that have it .is it some kind of molding plastic looking protective piece.where do i find them or is evrybody just spray painting across to make it look like one solid piece.hope this helps.thanks
I think pictures would help best
As far as I know, I've never seen a ZR2 come with the body molding you described. Bravadas and a few Blazers and Jimmys, yes, but not ZR2's. In fact, I don't think I've ever seen any 2 doors with what you are looking for, only 4 doors.
Again, as far as I know, this was from the factory, not a dealer add on nor aftermarket. |
side plastic
i will try to get a pic i really dont know to put it this but its starting to seem like the pics i saw maybe good spray painting but i check again .keep you posted
I am pretty sure it's just a bed lined lower panel. |
yup its bed lined
bed lined
guys i dont even know what that means ,how do i do it ?thanks
| All times are GMT -5. The time now is 02:09 PM. |
