Need some painting advice!
I just painted my lower part of the door, sanded it down and sprayed it with a spray can and didn’t apply clear coat yet because there is orange peel in some places and a little bit of paint run. Should I just wet sand with 2000 grit sandpaper to smooth it out and if need be apply more paint and then apply clear coat? Or should I apply clear coat to the orange peeled paint and then wet sand it afterwards? I want to make this thing look as smooth as possible!!
Originally Posted by Matt Evan Cinquini
(Post 709305)
Before - reapply as needed - clear coat and if needed lightly wet sand again - Finer grit the better - Rattle can is only going to do so well - Dupli-color holds up well as it has more solids in the paint ......
so just spray the clear coat over the current paint now? And I did use Dupli-color. I just suck at spray paint lol I have dupli-color clear coat as well. Should I wash the dried new paint before applying clear coat? |
so just spray the clear coat over the current paint now? And I did use Dupli-color. I just suck at spray paint lol I have dupli-color clear coat as well. Should I wash the dried new paint before applying clear coat?[/QUOTE]
No you miss understood me - Sorry - Before you recoat or clear coat the area Sand the imperfections out. Sand, tac rag, recoat, let cure, sand, tac rag, clear coat - sand if second coating or if needed, tac rag if recoating , let properly cure - wax - I perfer Mothers Wax .... |
Before you recoat or clear coat the area Sand the imperfections out. Sand, tac rag, recoat, let cure, sand, tac rag, clear coat - sand if second coating or if needed, tac rag if recoating , let properly cure - wax - I perfer Mothers Wax .... Oh you’re fine haha I’m still new to painting. The broken down process makes more sense. Now what grit should I use for sanding it down? |
At least 200 the finer grit the better esp on finish work .....
