Need your help gauge cluster not working
Hey guys I need some help I have a 1998 oldsmobile bravada and my gauge cluster stopped working the only needles that move are the oil, voltage, none of the others seem to work the digital odometer dosnt turn on the rpm, temp, and spedometer needles dont even move when im driving any idea on what I should do to fix this.
I had a similar failure in my '98 Blazer about 9 months ago. After a little research, i found that it wasn't uncommon for the gauge cluster to fail. There are several places out there that will service your cluster, basically refurbish it by replacing motors and re-soldering. I was NOT aware of that when the problem first hit my truck, and I had teh cluster replaced by my shop, and that was not cheap.
Google search should help you find a refurbisher near you. I would be willing to bet that your problem is internal to the gauge cluster, for sure. |
I just fixed it today turned out the power wire going to it was exposed
And it kept popping fuses so I used heat shrink and it fixed it |
| All times are GMT -5. The time now is 02:16 PM. |
