-   -   new to blazers, having problems with interior (https://blazerforum.com/forum/paint-body-interior-39/new-blazers-having-problems-interior-77076/)
blitz951 Feb 6, 2013 05:12 PM
I got my blazer a couple days ago, and its got quite a but of interior problems. First things I want to fix are: rear left seat won't fold away. The right works fine, the second gets stuck. Second, only the drivers side window switches work. Could this be that the window lock switch is out so the other switches are locked out? All the help I can get will definitely be appreciated. Thanks.
LeWhite Feb 11, 2013 12:11 PM
Since no one replied Id say look at the chils restraint system its in the rear door jams IDK
Twip Feb 11, 2013 01:18 PM
if only your drivers door panel rolls down the windows then either you have the lock out switch the wrong direction or a connection problem. the lock out switch might be faulty too. pull the drivers control panel out before you start pulling everything else, to me it going to be there.
as far as the seats go:
the little handles on the back of the seats attach to a cable which go down and operate the lock that hold the seats up. the cables do stretch from frustration when the seats dont fold down. if you can get in the back of the blazer and lift the handle a little bit to look underneath it, you should see the cable attached to the handle. i have seen people break them too. if its there you might be able to get a pair of pliers in there and pull just the cable and you might get the seat to fold down.
keep us posted. and good luck.
