-   -   New Custom Speaker Box (https://blazerforum.com/forum/paint-body-interior-39/new-custom-speaker-box-71804/)
Juggolow22 06-29-2012 03:42 AM
8 Attachment(s)
I decided to to put a new speaker box in my car because i had no trunk space. So i bought some wood and did it my self. This is my first box lemme know what you think.
Attachment 35075
Attachment 35076
Attachment 35077
http://i693.photobucket.com/albums/v...2/photo1-2.jpg
Attachment 35078
Attachment 35079
Attachment 35080
Attachment 35081
Attachment 35082
Juggolow22 07-01-2012 05:49 AM
Damn no comments?
chris015 07-01-2012 08:05 AM
I like it,any pics of the final product? Whats going in it and did you figure in what size it needed to be for the subs?
Juggolow22 07-01-2012 01:17 PM
I'm still at the resin stage. Gotta bondo it now. But I measured the speakers and it's gunna be 4 12" speakers. Two bass mtx and two ev speakers for voice.
serrasalmus 07-01-2012 02:33 PM
i hope that u calculated the right air space for them and just didnt decide to build one that you like as speakers need a certain cubic feet to perform like they should....
chris015 07-01-2012 03:11 PM
Exactly what i was going to say. Juggolow if you didnt calculate what the subs needed for airspace then i doubt its going to sound like it should.
check this out
Speaker Enclosure Volume Calculator
read it over and it can help you. If you dont know about the specs on building custom box's,unless you build the box to have the right amount of volume for what that sub requires for its max efficiency then its just not going to sound right. Building a sub box isnt just making a box,and cutting out holes,Much more then that. If you already knew all this then great,maybe someone else that doesnt will come along and read this.
Juggolow22 07-07-2012 03:57 AM
5 Attachment(s)
Originally Posted by chris015 (Post 527464)
Exactly what i was going to say. Juggolow if you didn't calculate what the subs needed for airspace then i doubt its going to sound like it should.
check this out
read it over and it can help you. If you don't know about the specs on building custom box's,unless you build the box to have the right amount of volume for what that sub requires for its max efficiency then its just not going to sound right. Building a sub box isn't just making a box,and cutting out holes,Much more then that. If you already knew all this then great,maybe someone else that doesn't will come along and read this.
I did calculate it. Thanks for the info tho. i started building one then had to take it apart because it wasn't calculated. This is the speaker system now. just waiting for all my speakers to come in. These are temporary. But its sick i like the way it sounds. I might put a dock under to make it sit higher.
Attachment 34642
Attachment 34643
Attachment 34644
Attachment 34645
Attachment 34646
Zzzblazer95 07-07-2012 04:10 AM
Looks pretty sweat nice job should have a divider in between all speakers so they dont work against each other fast way to blow your subs
