Oil pan skidplate
I have seen people putting engine/oil pan skidplates on. I am looking to find one just to sort of catch my oil leak. The seals are seeping and its not worth diving into all of that, I don’t mind topping oil off but I absolutely hate staining the driveway and marking my territory everywhere I park. Do these oil pan skidplates go back all the way to the rear main area? It is a bit hard to tell how far back it goes just from this picture.
https://cimg2.ibsrv.net/gimg/blazerf...33636bfbf.jpeg |
These skid plates, "underbody shields" in GM-speak, were a factory option. Your likely only source for them is a wrecking yard. You'll likely also need the mounting brackets for them.
These extend to the aft end of the oil pan. |
It seems to me that a skid plate isn't a great solution to an oil leak. For me, oil continues to drip onto my garage floor even with the skid plate installed. Oil collects in the skid plate and then overflows around the corners.
I suppose it might work if the skid plate were removed and cleaned regularly. But of course a better option would be to address the oil leak. |
Originally Posted by Stovey
(Post 758281)
probably rear seal,,we have two of these 98 and 2001 both are leakers...if it aint leaking it aint running...LOL
In the short term, you could get a drip pan for under the engine when parked in the garage. I need this for my old Mustang.
Regarding those two rubber plugs, if they look like these, they are for the bell housing. https://www.oreillyauto.com/detail/c...466?q=12554466 If you want to find the leak, I would think taking a few cans of engine or brake cleaner will be necessary to clean off the engine and then run it to see where the oil leaks. You'll want to take those bell housing plugs out too. I too have a leak that I suspect is related to the timing chain cover. It wasn't such a hassle to replace, I'd have done it. As it is, I'm happy to live with it for now and when/if I ever have the engine out, I can do a proper repair then. |
| All times are GMT -5. The time now is 03:12 AM. |
