-   -   Overhead console (https://blazerforum.com/forum/paint-body-interior-39/overhead-console-4485/)
WorstCases 10-05-2009 05:38 PM
Wiring Overhead display
Hello.
I'm having a 00 Blazer with temp/compass only.
Went to the junkyard and got myself a new display (out of an 01) with all the fancy stuff in it.
However: The first six wires of the new MPG display match my old display.
But then there are two (not only one) additional wires on 8 (orange) and 9 (yellow).
Can anybody pease tell me what do do with them?
Thanks.
WorstCases 10-05-2009 05:53 PM
some progress
I just found out:
(8)orange 14-Battery Positive Voltage
(9)yellow 15- Trip computer/nav class 2 serial data link
Mor information on: http://www.hotrodders.com/forum/96-b...ion-10959.html
So now my question is regarding Pin 8 (orange):
What means PAttery positive voltage? Does the display need to be provided with power at all times (even if the ignition switch is in the off position)?
96Blazernut 10-05-2009 07:12 PM
This will tell you all you need to know to install one of these
http://www.s10forum.com/forum/f200/o...nstall-214399/
I used it when I did my install.
Also when you get it installed to set the variance on it. There is a section that tells you how.
Once thats done they work great.
Also look here if you end up with the ones with the MPG/Trip computers in it
https://blazerforum.com/forum/audio-video-electronics-8/blazer-overhead-display-upgrade-20854/
swartlkk 10-05-2009 08:53 PM
Here are the schematics from the 2000 FSM:
Driver Information Center w/o Trip:
http://i11.photobucket.com/albums/a1...IC_wo_trip.gif
Driver Information Center w/ Trip:
http://i11.photobucket.com/albums/a1..._trip_1of2.gifhttp://i11.photobucket.com/albums/a1..._trip_2of2.gif
chevynuts 11-30-2010 10:55 AM
Originally Posted by swartlkk (Post 28831)
So it looks like you are correct, however, I only have a partial reference to the wires you listed. Also attached are the 98 w/o trip & w/ trip schematics.
Hi Kyle,I,m new to this site and need help. You seem to be the one to talk to.I want to put a long overhead console into my 2003 ZR2.Should I purchase a specific year[to have compass built in]? The parts list would be nice ,e.g. console,mounting bracket?,temperature sensor,wiring plugs [how many].What about compass? How does that hook up?What does the temperature sensor behind grille look like? Thanks for any help! I am going to do this and will make a record of "what needs to be done" start to finish with pics. I put rack & pinion steering in my 66 nova with tubular upper & lower control arms and shared all the info to save others trouble and money.
chevytruckdood 11-30-2010 11:15 AM
yeah i got a fullsizes overhead console laying around to install in my blazer. weve done it before on one of my buddys bagged s10 and turned out great there...... got one for $5 at salvage with wire included........ i love the you pull salvages out in tulsa...
veranduschuck 05-13-2011 10:03 PM
i joined for this and now im leaving but i wanted to say THANK YOU first
ive been looking for this all day
02Blazer4dr4x4 06-17-2011 12:21 PM
Hello all, I'm posting my question here because you seem to have the info I need so here's my question...is there anyway to reset the outside temp on my 02 Blazer. It has the temp/compass the compass works fine but since it was in an accident the temp reads oc. I checked the wires in the area of the damage from the accident and they are good. Is there a fuse or reset to correct this or do I need to keep looking for a wiring problem? Thanks, Oh and I've replaced the sensor so I know that's good.
Rottidog 06-17-2011 02:04 PM
If you can't find the fuse, disconnect the battery for 5 mins.
02Blazer4dr4x4 06-20-2011 02:19 PM
Thanks, I'm ready to try just about anything right now.
