-   -   Oversized door pin bushings installed :) (https://blazerforum.com/forum/paint-body-interior-39/oversized-door-pin-bushings-installed-89003/)
Captain Hook Aug 16, 2015 08:02 PM
The new bushings come in two sizes: .010 & .020 oversize. Best to have both on hand before starting the job. The bushings are splined so they do not rotate when the door is opened and closed, and they must be pressed into the hinges. Try the .010 bushing first, if it's sloppy, use the .020 bushing. Reaming should not be necessary. The hinges MUST be square, and the pin should slide in easily, with no binding, BEFORE hanging the door. If the bushing fits too tightly in the hinge, the inside diameter will be distorted and the pins will bind. The pins are splined to the other half of the hinge so they rotate when the door is opened and closed.
Toocute350 Nov 5, 2015 08:29 PM
Toocute350
I have the same problem with my driver side hinge on the door it self.Not the hinge on the cab.I talked to a guy named eddie awhile back at total automotive.I told him my situation he told me about the over sized bushing size also.The top pin hole on the driver door is ovalon.I will try and get a oversized bushing in it and then fill it in with jb weld.Thanks for posting this matter.You think GM Would have made smaller hinges like the newer gmc and chevy trucks.I guess having power locks and window`s add alot more weight than normal but still.:)
45Frank Nov 6, 2015 06:01 AM
I repaired mine three months ago and used DuraCraft Epoxy also and so far so good, and that's with my daughter using it. :icon_razz:
blazen_red_4x4 Jan 10, 2016 08:45 PM
I just had to replace the passenger front ones last weekend. That side is still using factory sized bushings, the tops completely fell apart... The driver's side with the oversized bushings though, still like new almost a year later :)
NeoBlazin Jul 30, 2019 10:04 AM
Where did you get the over-sized bushings? Links please.
blazen_red_4x4 Jul 30, 2019 04:40 PM
Links are in the first post, but they're dead, looks like they no longer produce them any more unfortunately... shame too... seemed to be the only solution short of welding the bushing hole shut and redrilling it for a stock bushing...
swartlkk Jul 30, 2019 05:48 PM
Part numbers from the links above were as follows:
TAI-GMB017A -- 0.010" oversized
TAI-GMB017B -- 0.020" oversized
A quick google search should give you some purchasing options.
I have updated the links in the OP as well.
blazen_red_4x4 Jul 31, 2019 06:27 AM
Oh nice find, I actually could not find them! Thank you very much sir! :icon_worthy:
Daniel Piontek Jul 14, 2021 10:20 AM
Finding bushings and price for sagging doors on a S10
Inknow this is a super old thread nut I have a 02 s10 blazer xtreme (love that dam truck, black 126,000 mi lol) anyways, I found this thread and found mine with a copy/paste of the part numbers on Google chrome and ultimately found mine on Amazon. I got both .010 & .020 for about $50. I know that seems like a lot considering they are nothing but brass fittings but it saves me the trouble of messing around with the striker latch asst every time I close the door. Sorry for the hook I wrote here but Inhad to tell someone and thank the guys that made this thread pods. THANK YOU ALL FOR SAVING MY TRUCK! You all are the best.
