Paint Codes
Does anybody know the paint code or name of the dark blue color on a 99 Blazer. I would like to paint the chrome sections to match the body. Thanks ahead of time for any help on this.
Its on the RPO code sticker in your glove box. Down at the bottom of the sticker.
This is the only blue I see for a 1999 Blazer .Paint Code WA9792 Indigo Met
Hope this Helps ? Look in your Glove box and Double Check this code Number and see if it Matches yours ? |
Thanks for the info guys. I`ve seen that Indigo Met in Dupli-Color in Advanced Auto and thought it was right. Just wanted to make sure. I`ll check out the code in the glove box today.
I`ve seen that color listed on a Dupli-Color spray can and it looks correct. I didn`t see WA9792 listed on the tag in the glove box though. Is there another place to check? Since this will be up front on the grill I want to be as close as possible.
Hello wa number is on tag in glove box if not you can take your vin number to a local gm dealer they can decode it and tell you the wa number for the paint. Thanks jim
| All times are GMT -5. The time now is 02:51 PM. |
