Question for the metal fab guys
I want to install a 7 pole trailer connector on my blazer
Would like to mount the connector threw the bumper just not sure what type of hole saw blade to use Is a decent bi metal blade going to do it ? |
https://blazerforum.com/forum/attach...-hitch-005-jpg
Make sure you clear the wires behind there while drilling. Hole saw works great. |
ya home depot got some good hole saws.
personally i use the cheap harbor freight set. |
Originally Posted by 10-78 edac
(Post 574888)
Make sure you clear the wires behind there while drilling. Hole saw works great. the connector I got has the 4 wire and 7 in the same unit ,not a fan of seeing the wiring hanging all the time was thinking of right of the plate , mine is a 2dr so no tire under the back any how using the existing hole Multi-Tow® 4 Wire Flat to 7 RV Blade & 4 Wire Flat |
Thread jack where is the connector located. My RPO says i have one but havnt seen it. Unjack
Should be a bundled wire with tie strap taped up on the end
Originally Posted by LeWhite
(Post 575126)
I only plan on grabbing tail and signal power there , going all new for brake controller to the engine compartment |
| All times are GMT -5. The time now is 06:03 PM. |
