-   -   Remove pinstripe and molding (https://blazerforum.com/forum/paint-body-interior-39/remove-pinstripe-molding-22160/)
bensale56 07-28-2008 12:21 AM
First off im new to the forum and liking it but to get to my ?, i took off the passenger side moldings and it lokks great but i was wondering if i could take of the front and rear moldings with the same chrome and black pattern, it looks as they are connected to the bumper idk. and my other question is how do you remove the pinstripe properly? thanks[align=left] [/align]
whiteblaze 07-28-2008 07:38 PM
RE: Remove pinstripe and molding
Ill try and answear this the best i can, my blazer is a 98 and it had the small black and chrome plastic trim pieces around the wheels, I removed them pretty easily, is this what u want to do as well? if so there should be small bolts around the bottom of the moulding take them out and carefully pull the trim off. EDIT-Ok i just re-read ur post, but ill leave that other stuff there in case you need it, the front and rear bumper trim should be the same as the sides but check underneath if you can to see if there are any small bolts or anything that might be holding it on. as for the pinstripe, im not to sure, i would try a heat gun or a hairdryer and remove the glue with solvent.
bensale56 07-29-2008 02:10 PM
thanks whiteblaze, yea i got the pinstripe off easily and for the trim around the bumpers they apear bolted in so ill see what happens lol
noom14921992 07-29-2008 03:06 PM
put pictures up once you are done
whiteblaze 07-29-2008 07:48 PM
ok i thought they might be bolted in, try and take them out like you wanted to do, but trouble is, whats under the trim? it might turn out to be an ugly mess and more of a headach. but anyway try it and let me know how it goes and post pics if you can. good luck
bensale56 07-30-2008 01:16 AM
yea i need to find my camera to put pics up ive been dying too lol, but thanks for the help...yea the only thing is once i took the molding off and cleaned it there is still spots with black spots that are hard to remove
whiteblaze 07-31-2008 08:46 PM
Im not too sure what you mean, are there pieces of trim that wouldnt come off? and how does it look without it on, do you need to fill the holes in and smooth it out or is it pretty decent? and your wellcome for the help
noom14921992 07-31-2008 09:41 PM
i want pics
whiteblaze 08-01-2008 09:08 PM
He cant find his camara, cause im waitin for pics as well!! lol
