-   -   remove rear window trim? how? (https://blazerforum.com/forum/paint-body-interior-39/remove-rear-window-trim-how-14531/)
brunosrk Nov 18, 2007 06:15 AM
The right rear side window on my 2nd gen (03) 2 door seems to be leaking. How do I get the exterior trim off to see if the glass is sealed properly?
Chevy Lover Nov 18, 2007 02:00 PM
RE: remove rear window trim? how?
[ol]Remove the upper and lower front seat anchor bolts.
Remove the rear seat belt lower anchor nut.
Remove the assist handle.
Remove the coat hook.
Remove the endgate or the liftgate opening door sill trim plate.
Fold the rear seats down.
Remove the jack storage cover (left side only).
Remove the screw that retains the upper body side trim body side trim panel to the vehicle (left side only).
Remove the upper body side trim panel from the vehicle.
Feed the seat belt through the trim panel. [/ol]
brunosrk Nov 18, 2007 02:55 PM
Thanks for the reply, but what do those instructions have to do with the EXTERIOR trim?
swartlkk Nov 18, 2007 03:25 PM
By removing the interior trim and using a garden hose on the outside of the window, you can narrow down where the water is coming in through. Looking at it from the outside (if you even can) won't tell you the whole picture.
Chevy Lover Nov 18, 2007 10:21 PM
ORIGINAL: brunosrk
Sorry, just my impression of what you needed. I looked to see if you had a photo gallery or even a pic of your truck and couldn't find one.
I thought that you were referring to the stationairy side glass, which is sealed in place with urethane and I don't know how you would see that from the exterior, so I thought you meant INTERIOR trim.
