-   -   Removing paint from vinyl? (https://blazerforum.com/forum/paint-body-interior-39/removing-paint-vinyl-27990/)
hubbmatt 02-25-2009 07:34 AM
I had a little boo boo when I painted my arm reset and I want to completely strip the paint off before the 2nd go around. What should I use so I don't damage the vinyl???
IROCZ 02-25-2009 07:48 AM
RE: Removing paint from vinyl?
try some thinner
encryptedzion 02-25-2009 09:53 PM
Avoid products containingAcetone since that will degrade/damageplastic (vinyl).
Products containing Isopropyl Alcohol will not degrade/damageit. Or use straight Isopropyl Alcohol,pour it on to a cloth/rag and use in a well-ventilatedarea at room temperature. It will not leave a residue after it oxydizes (dries) either...but it may takea couple of"clean areas" on the rag to get it all cleaned-up.Depending on the amount of paintneeded to remove, it may take some time and scrubbing to remove the material.
Hope this helps!
