-   -   Removing Stickers (https://blazerforum.com/forum/paint-body-interior-39/removing-stickers-42352/)
truesmack 03-18-2010 05:12 PM
Removing Stickers
Just curious if anyone out there knows how dealers remove those old stickers advertising there dealership, mine has some stickers and really I see no reason to be a free advertisement to them, but really don't care to scratch up my truck, thanks for any info.
Rogue 03-18-2010 05:49 PM
Since their a sticker, fishing line is pretty much out of the question. < a good tool for de-badging.
A hair dryer, finger nail and patience should do the trick. Followed up with alcohol or even windex to remove the stick-um residue.
abig84 03-18-2010 08:12 PM
yep... i just bought a old fleet truck where both sides hood and tailgate are covered in stickers. i just spent 2 hours and im only 1/3rd done :( you CAN use a metal razor blade if your realllllly good. i used to detail cars and used one all day today and only scratched the paint a few times due to the razor grabing and flipping on me, truck is a junker so not to worried about it
RangerG 03-18-2010 11:40 PM
Depends how long it's been on there. I had the words "Mayfield" on the back of mine. I decided the same thing you did one day and just peeled them off with my fingernail. It may have been on there for a few years.
It was pretty warm out when I peeled mine off, so try using a heat gun or hair dyer and some patience.
sifd4x4 03-19-2010 12:21 AM
x2 on the heat gun. if you can get them warm enough you can usually just peel them off by hand.
CraigSnedeker 03-19-2010 02:30 PM
Hair Dryer will do the truck
But as I experience in removing trim sticker ahheisive, it can burn your fingers if you heat it up to much. I had a can of Sticker Adheisive Remover by 3M (NOT FOR PLASTIC!) and it softens up the plastic.
oktain 03-19-2010 02:44 PM
Believe it or not, WD-40 helps to free up the glue as well... I used that **** with a rag to take off industrial double sided tape from a set of HID balasts I removed recently. (long story.)
CraigSnedeker 03-19-2010 02:56 PM
Never knew that :)
Sisk 03-19-2010 03:50 PM
WD-40 is a good alternative to something like goo gone. It's easier to find too. Probably not much cheaper though.
x100 on the previous suggestions. I took off my dealer info and badges with a heat gun, and lots of goo gone.
And Pat...your comment reminds me of that franks red hot commercial "I put that **** on everything!" lol.
abig84 03-19-2010 06:41 PM
what i used on my other truck was lighter fluid. its pretty much what was on the shelf. i just smired it in the glue, waited a few seconds and it just turned into gooey snot that you could just wipe right off. i think pretty much anything works
