Replacing cloth with leather
Looking into replacing my cloth factory seats with leather seats. My seats now aren't power seats and was wondering if I found power leather seats is there a hookup for them in my 2002 blazer ?
Look under the seats, you probably have the hook-ups for power seats. My '02 does & many other 2nd gen blazers. Reason being "factory options" that were mostly done at a dealership.
GM put the power & plugs under the seats for those that wanted heated seats from the factory & it's cheaper to do that than to have a dealership run new wiring. Basically - just include the option for that option if needed, is better business sense. Also try SEARCH, it works well & I know this was talked about in the last few months. |
replacing manual seats with power seats is easy...you will only need to run 2 wires (power and ground)...make sure you connect the power wire to something that is always on so the seats will work even if the key is off/out...i forgot where i hooked mine up to but just use a test light and check the fuses for a constant source..now if you add heated seats then there will be a 3rd power wire..connect this to a source that only comes on when the key is turned on so you don't run down the battery by not turning the heat off..if you need more help let me know...
GM used the same harness on blazers. Even if the plug isn't under the seat I bet the connection/plug is under the dash. Might have to get the wire from the dash to the seat and put a fuse in for the option. No need to tap and add when the factory stuff is there.
| All times are GMT -5. The time now is 03:49 PM. |
