Swapping Seat Bracket 98 LS blazer
Hello, Im just wondering if anyone can help me with swapping my 98 blazer LS seat bracket with one form 98 LT. I searched on here and google for how to remove the seat brackets, but no luck. Its got to be simple im just not getting it for some reason. thanks for the help
never mind i figured it out
I've replaced the seats a few times, but never the brackets.
Assuming it's a few bolts, but what did you figure out? |
Yeah it was pretty much just a couple of bolts. First you had to remove the seat cover it's held on by clips you roll it up and then there's some bolts on the side. then you need to take off the lumbar knob and the lever for the seat adjustment to slide forward or backwards then there's a 4 bolts underneath the cushion that you couldn't access before but now they are visible. that's pretty much it the next time I do it it should go quite a bit quicker. The one I removed was the passenger side without any Motors and stuff so maybe that might be a little more difficult. My description is not very good but hopefully it makes sense to somebody
