-   -   Tailgate Gap of Body Lifted Blazer (https://blazerforum.com/forum/paint-body-interior-39/tailgate-gap-body-lifted-blazer-70498/)
Thermm 05-05-2012 09:51 PM
Does anyone have a suggestion on what to use to fill the gap left between the lower tailgate & top of rear bumper on a body lifted 1989 S10 4x4 Blazer?
I want to keep the original bumper height, so any mods to the bumper bracket to raise the bumper closer to the bottom of the tailgate is not an option.
I once saw such a specific item in JC Whitney Truck Catalog a long time ago prior to my lift.
nunya 05-05-2012 10:16 PM
Make a gap guard out of the filler panel below the rear doors of a barn door fitted Tahoe? (I've also seen similar factory fillers on late 90s early 00s Explorers as an off hand thought) They are black textured plastic so would be easy to manipulate into the shape/size you need.
Thermm 05-05-2012 11:19 PM
Thanks for the suggestion. I'll look into that material. It would greatly reduce the amount of "roosting" from the tires thru this gap during mud/water driving conditions.
Rottidog 05-05-2012 11:59 PM
I have a 2nd gen blazer with a 1st gen BL (2nd gen never had a 3" BL only 2", only 1st gen). Needless to say the bumper brackets didn't fit for the previous owner. I have some aluminum diamond plate that I'm going to use to fill the gaps from the factory bumpers to the BL'ed body. Get it powder coated matte black & put it in place, it should be cool.
neo71665 05-06-2012 02:44 AM
Best looking is to make a taller bumper that fits the hole better.
Otherwise go to any hardware store and get a rubber strip. Just screw it in back there. Still gonna have that goofy body higher than bumpers look.
For my gap guards on the side I used some 1/4 inch thick rubber mat. Taped some paper under it, marked, cut, and adjusted it in paper until I got something I liked. I then cut them out of the rubber and bolted them in place. Whole process took less than an hour for all the wheelwells so I can't see the one back taking that long.
Thermm 05-06-2012 11:15 AM
1 Attachment(s)
I like Rottidog & neo71665's idea. I have a big diamond plate & chromed bumper already on the back & adding a little more diamond plate filler panel above it should match whats existing. I'll probably modify the brackets so its tucked in closer to the body than it presently is.
The Bracket that came with the bumper stuck it way out in back, never got around to modifying it. Been waiting for a solution to the gap. Now I have next Saturday's project.
Thanks guys!
Rottidog 05-06-2012 10:12 PM
I'd add auxiliary reverse lights to the bumper. But that's just me lol & painting it or powder coating. I have a company next door that does powder coating & it kicks ass.
Thermm 05-08-2012 09:41 PM
Interesting idea about adding reverse lights to the bumper.
I have access to some very large white led strips that i could add to the diamond plate filler material for the gap left by the body lift.
