tailgate inside panel removal
Hello,
I was wondering how you would remove the panel on the inside of the tail gate on a 99 s-10 blazer LS. Late last year I had moved half way cross country and had my blazer in a tow dolly and the altitude change during the second day of travel had changed my tire pressure and caused my right front wheel to come loose and slightly come off the dolly. I tried to see if I could just push it back on since it was only slightly off but in the process I dented my tailgate and didn't get it back on the dolly. So I am trying to get under the panel to see if I can just pop the dent back out. |
The panel is just cliped in i believe, its been a while since i removed it. So yes the panel is very easy to remove, BUT i dont think you will be ablr to pop the dent out because of all the crap(eletconics and hatcch release etc.) located IN the tailgate.
And on second thought...what kind of vehicle do you have? im assuming since you said tailgate and not lift gate you will be ok. I dont know who to take tyhe panel off of a lift gate nor do i know what the insides of them look like. |
Rear door/tailgate panel removal
Hello,
I have a 1995 4 door Chevy s10 blazer. I can not get the rear door to open. I was told i have to take the panel off in the inside but i can not figure it out without the door being open, if that makes any sense. I can pull on the latch inside and I can hear stuff move inside the panel so I do not think the wire from the latch is broken. So my question is.. How do i remove the panel with the door being shut? or Dose anyone know what could be stopping it from opening? Id appreciate any help at all! Thanks! |
Like HcHawks09 said, the inner frame work and other stuff is in the way. It might be hard to get to the dent. I also believe that it just pops off, but it's been along been a long time for me too. I do think there are a couple screws you need to take out. Double check before you go yanking on it. I also assume that its a 2 door with the drop down tail gate. If its the lift gate it's probably about the same deal, a couple screws and it pops off. For bigbrink, I don't know what to tell you. I haven't dealt with the lift gate.
Bigbrink. I read somewhere that there is an emergency release somewhere back there. I think its under the carpet on the door or something. Do a search, you should be able to find somehing
Originally Posted by Bigbrink
(Post 430148)
Hello,
| All times are GMT -5. The time now is 05:12 PM. |
