Tire carrier bushings
Maby this forum can help me.
I have a 97 Blazer LS 2 door that has the spare tire mounted on a hinged rack that swings out like a door at the rear of the car.
The problem is the bushings are worn and this rack makes a lot of noise.
Where can I find new replacement bushings?
Are they control arm bushings?
It looks like there are two bushings per bracket (#11 and #26)
11 - 12546658 BUSHING SPA WHL CARR UPR PIV PIN ST1(16) (P16) 95-05 - 2
26 - 12546658 BUSHING SPA WHL CARR LWR PIV PIN ST1(06-16) (P16) 95-05 - 2
Here's a list of the parts with a link to purchase them
1996 Chevrolet Blazer 4WD Spare Wheel Carrier, /Outside RR Mounted - TS0751501L43MW2T10516
i just had this same problem like 3 weeks ago, its just little plastic bushings, like 18$ each i think? its easier to do if you have like a table vice or something to hold it while you smack out the old ones
are these compatiable with the older style of spare tire carriers? i have 92 and the pin retainers have mysteriously disappeared and ive lost the bottom bushings. i keep getting the 12546658 part number but not sure if it works with my application.
GMPartsDirect was the cheapest i found and just got them.
You're welcome
The link further up has specific part numbers and you can also find a lot of other diagrams. It's easier than calling the parts desk or getting a printout of it from the dealer
