top removal.
i have an 89 k5 blazer and i am wondering where i can find the tool or wrench to take the bolts out to take the top off of the blazer.
thanks. |
A regular combination wrench is all that is needed. You could use a ratchet and socket as well. These are general tools. If that is what you need, your local hardware store or autoparts store should have the necessary hand tools.
There will be one bolt all the way in the back that is somewhat hidden. It goes up from under the bed rail and you may have to remove the trim if your truck has side panels to get to it. |
thanks, i found everything i needed,
| All times are GMT -5. The time now is 12:51 PM. |
