Go Back  Blazer Forum - Chevy Blazer Forums > Modifications > Paint, Body, & Interior
Reload this Page >
wat are the BL that they are made??????
Community
Search
Old 09-15-2008, 11:28 PM
WolfPack's Avatar
Default RE: wat are the BL that they are made??????
I believe you should have 10...I have 12. Which is odd for a 2000. Guess I'm late model year 2000.
  #22
Old 09-15-2008, 11:37 PM
Blazin_1t_up is an unknown quantity at this point
that could have somethin to do with ithow should i lift the body up???
  #23
Old 09-15-2008, 11:55 PM
WolfPack's Avatar
Once you get everything disassembled and prepped, you loose one side's body mounts, but you don't remove the bolts. Just enough to let the body pivot. Then you go to the other side, and take those body mount bolts out. Then I used a foot-long section of 4x4 wood post with my floor jack, and just lift up the body. It will seperate from the frame, and you lift it up just barely enough to slide the lift puck in.
Then you put those bolts back in (don't tighten them), go back to the other side, repeat. This time you locktite the bolts and torque down. Go back to first side, remove bolts, locktite, replace.
Done
Aside from that pesky 'reassembly' thing!
  #24
Old 09-16-2008, 12:01 AM
where can i get a torques bit that big..... for the frontbumper
  #25
Old 09-16-2008, 02:25 AM
WolfPack's Avatar
Not sure if you need a Torx bit. 98+ sure don't, but if you do need a Torx bit to get the bumper off, Sears has a nice set, or you can go cheap and go to Harbor frieght/Farm and fleet/Northern Tool and pick up a set.
  #26
Old 09-16-2008, 03:15 PM
yeah i need a BIG one and idk abt the back bumper
  #27
Old 09-16-2008, 05:24 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
Oh yeah you definately need two different torx bits. I had that problem, I got one that fit the rear, went back to a friends garage and realized that the front is a different size. So I ended up going back to Ace Hardware and getting the other bit.
  #28
Old 09-17-2008, 11:10 AM
you wouldnt happen to kno the sizes would you?
  #29
Old 09-17-2008, 01:33 PM
Well I dont know off hand right now but I do know that the bit's are at my parents house, so if you can wait till friday or saturday then I can get ya the sizes.
  #30
Old 09-17-2008, 08:08 PM
well ur gonna laugh buit i used a sized allen wrench and took it off today
Quick Reply: wat are the BL that they are made??????
