-   -   Wheel spacers (https://blazerforum.com/forum/paint-body-interior-39/wheel-spacers-1835/)
quontush 12-18-2005 01:24 PM
Wheel spacers
Would one or two inch wheel spacers for the rear tires hurt anything? Im just looking for somthing to kick them out a little bit, could i use any spacers for the front?
2001blazer 12-19-2005 01:11 AM
RE: Wheel spacers
well i do know that by doing spacers u put alot of pressure on the axel but im no expert at that kinda stuff just my opinion
hodgecr 03-01-2006 10:22 PM
RE: Wheel spacers
I put 1" spacers on front and 2" on rear.I have 99 2WD and the rear are no problem at all and the fronts rub just a little bit when backing and turning all the way. I have 255x70x15 and the stock 5 spoke wheels. I think it looks wider and the way the factory should have done it in the 1st place. Stock has the wheels way too far in, in my opinion.Also I bought the aluminum instead of the steel one and have had no trouble what so ever.A cheap mod for your money.
sledneck16 04-21-2006 08:02 PM
RE: Wheel spacers
I have an 05 blazer 2dr 4x4 with 2' aluminum spacers rear and 1.25' front --looks better than a ZR2 in my opinion--and rides WAYYYY better than stock
swartlkk 04-21-2006 08:27 PM
RE: Wheel spacers
Holy old thread! Good going guys!
Anyway, I would stay away from spacers. Problem with them is they will make you chew through wheelbearings like they are going out of style. The spacers will put much higher loads and moments on the bearings causing increased wear and possibly catastrophic failure.
