Wheel spacers
Old Dec 18, 2005 | 01:24 PM
quontush's Avatar
quontush is an unknown quantity at this point
Default Wheel spacers
Would one or two inch wheel spacers for the rear tires hurt anything? Im just looking for somthing to kick them out a little bit, could i use any spacers for the front?
Old Dec 19, 2005 | 01:11 AM
2001blazer's Avatar
2001blazer is an unknown quantity at this point
Default RE: Wheel spacers
well i do know that by doing spacers u put alot of pressure on the axel but im no expert at that kinda stuff just my opinion
Old Mar 1, 2006 | 10:22 PM
hodgecr's Avatar
hodgecr is an unknown quantity at this point
I put 1" spacers on front and 2" on rear.I have 99 2WD and the rear are no problem at all and the fronts rub just a little bit when backing and turning all the way. I have 255x70x15 and the stock 5 spoke wheels. I think it looks wider and the way the factory should have done it in the 1st place. Stock has the wheels way too far in, in my opinion.Also I bought the aluminum instead of the steel one and have had no trouble what so ever.A cheap mod for your money.
Old Apr 21, 2006 | 08:02 PM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
I have an 05 blazer 2dr 4x4 with 2' aluminum spacers rear and 1.25' front --looks better than a ZR2 in my opinion--and rides WAYYYY better than stock
Old Apr 21, 2006 | 08:27 PM
Holy old thread! Good going guys!
Anyway, I would stay away from spacers. Problem with them is they will make you chew through wheelbearings like they are going out of style. The spacers will put much higher loads and moments on the bearings causing increased wear and possibly catastrophic failure.
twistedmetal
Feb 8, 2018 07:04 PM
calee4nyaboy
Nov 20, 2009 11:48 PM
nofear17bmx
Feb 11, 2007 08:59 PM
Bosaliniee
Suspension Tech
Jan 28, 2007 10:23 PM
nails5240
Tires and Wheels
Jun 14, 2006 12:38 AM
