Will 2000 Blazer LT interior parts fit in a 1996 LS?
Hello, my brother is going to junk his 2000 Blazer LT 4dr 4x4. I am planning on upgrading the cloth seats in my 1996 Blazer LS 4dr 4x4 along with other parts as well. I wanted to know if his power front leather seats will fit in my truck along with the rear bench seat, and if any modifications are needed. I would also like to swap the matching leather door panels and the center floor console in between the front seats, but I am not sure if those will fit either. I would greatly appreciate any input.
Anything can be done with enough time and money, but the rear bench seat will be the easy. Unbolt the old, Bolt in the new. The front seats are slightly different where the bolts mount up though. If you do a search, I think you will find something about the front seats. The door panels I believe are different. and the console may be possible.
Whats wrong with ur brothers 200 blazer? you should take his blazer and make his work with using ur 96 blazer parts. 2000 blazer is much better than 96 blazer
If you mean the front end, I would agree, And if you look at his truck, he has done Alot of work. Beautiful truck I must say.
Originally Posted by kickme005
(Post 362063)
i got a 95 blazer too and my runs perfect too. the only reason i like the 98-up blazers better than the 95-97 is cause the A/c controls and the digital PRNDD23 and body mpgs. but i love having my blazer cause i use the cup holds on the glove box door all the time.
98-up rear seat is exactly as 95-97 the same but 98-up just has the added head rest. try bolting in the front 2 seat but other people on here says all the holes dont line up 3 out of 4 but not sure never tired it. you can take ur bros front end parts and do a dront end update. if ur just taking his seat just put ur old seat in his and sell it as a hole saying engine need replace and you'll get a lot more money than the junkyard. if the transmissions good with that alone you culd get more than junkyard/ also if ur looking for upgrades for ur 95 see if he has mode button insead of on/off. in the overhead console. also if you really wanted to put the 98-up style door panels from ur bros blazer to urs then u need the stuff inside the door too. doors are the same. but it be easyer to go buy some leather door panels. also there are 2 different style leather door panels. the style like ur but instead of the cloth it s leather or the style that its leather the whole way over the top of the door and around the handle handle. i think they came in Bravada. its basically like ur panel but not stich to septate it if his came with rear disc brakes u could also put them on urs. drum to disc |
Alright. Thanks for all the info. I'll keep all these swappable things in mind.
| All times are GMT -5. The time now is 02:45 PM. |
