Will this cowl hood work ?
Just want to make sure this hood will fit even though it says it is for an S10 pickup I have an S10 Blazer so I don't see why it wouldn't work just want to make 100% sure first.
KeyParts Cowl Induction Style Hood for 82-93 Chevrolet S10 at Andy's Auto Sport Also would like to know if I can use these panels as replacements on my blazer if I just cut out the section where the tail light is will the measurements overall still be the same as the Blazer because these are exactly what I need to fix the major portion of my rig. http://www.andysautosport.com/chevro...c00008804.html Thanks |
Yes on the hood.
I don't think so on the fender. You can do some measuring on the trucks compared to your Blazer but I'm thinking the rear end body work/lights/etc are different due to a tailgate vs a drop gate that is not a tail gate. Not sure what to call ours when trying to compare to a truck's tailgate. |
From the rear edge of the door to the grille a suv and truck are the exact same. The front frame, interior, sheet metal, and glass all swap.
Patch panels cut up can be used but the the fender is different. Behind the rear tire is lower and a bit longer on a truck. The tail light buckets are the same but tailgate area is also way different. |
thanks guys
| All times are GMT -5. The time now is 08:24 AM. |
