Window trouble.
Hello, having issues with the driver power window being intermittent. Replaced the motor and the switch because it would be slow rolling up and stop and not want to budge unless ya gave it some time. Now with the new motor and switch I'm having the same issues.
any advise? |
I've had a similar problem over the years. It'll go weeks with no problem and then will get stuck partway up.
I'll then pry up the switch panel and wiggle the electrical plug which fixes it. I suspect the issue might be the electral connector itself or the connections to the pins. I will be taking a closer look at them someday soon. |
Mine dosnt seem to be the plug. The switch constantly has power because I can play with passenger window while the driver won't roll up. Without moving anything just wait and it will roll back up after 20-30 mins.
So I have 11.5 (-11.5)volts to the motor when rolling up and down ignition switched to on but not started. 14v(-14) volts to the window motor with engine running. Could I have a faulty window motor from the parts store?
Originally Posted by Clab
(Post 741640)
So there is a possibility you could have a damaged wire, poor ground, or a poor connector. |
Think I fixed it. Was lower voltage from sitting in the driveway for a week. But when I went to O'Reilly originally for a window motor the guy took the window motor out of the box and I gave him my old one for the core. Think he got them mixed up and gave me my old one back. Went to autozone and got a window motor installed and it's going up and down fast! Now just have to figure out some new door panels because mine are trashed
My 2003 Blazer Xtreme's windows are working fine, but this thread prompted me to mention something I've noticed over the years. Several times when I've meant to raise the window and absent-mindedly pressed the switch in a sloppy manner, like with my finger only part-way on it, it slows down as it goes up and then stops. Pushing the switch again is no use. I have to let it set awhile, then it works as well as ever.
Dunno why that happens. Maybe I'm not fully depressing it so it's getting insufficient current when I do that. This probably helps no one, but, there it is, another shared Blazer experience. |
Originally Posted by BlazerXtreme03
(Post 746878)
