-   -   Wiring Halos (https://blazerforum.com/forum/paint-body-interior-39/wiring-halos-64989/)
98chevyblazer Nov 12, 2011 08:41 PM
Wiring Halos
Alright so I know you can wire them to the turn signals but I dunno what wires I should wire each to. Coming off the halo is a red and a white wire and on the turn signal there's a blue, brown, and black wire. I don't want it to flash with my turn signal I just want it to be lit up when i have my parking lights on. Any info on this would be greatly appreciated :icon_teeth:
http://i1239.photobucket.com/albums/...v122011001.jpg
juanfpina Nov 13, 2011 12:38 AM
The white will be grounded while the red goes with the brown wire I believe which will have them on when the parking lights are on, aka when you press the top switch but dont turn on your headlights.
98chevyblazer Nov 13, 2011 03:34 PM
So white to black and red to brown?
juanfpina Nov 15, 2011 01:34 AM
No, if you wire it that way it will blink because the black ground is weird, you have to ground it to the bare metal chassis.
98chevyblazer Nov 15, 2011 06:28 PM
What does this mean?
warthogdriver Nov 15, 2011 07:01 PM
he means run it to a spot on the truck that is bare metal. there is a ground on pass side by battery, or just make your own with a sheet metal screw and fasten the wire to the body.
98chevyblazer Nov 20, 2011 05:23 PM
hmm okay ill try this out, thanks
