ZR2 Fender Flares
Hey Everyone, so ive been considering painting the fender flairs on my blazer for a good amount of time now. I would be painting them with the black bedliner stuff, but im not sure if it will bond properly. What kind of prep work would i need to do to get it to bond correctly? Also, im starting to get a tiny bit of rust on the bottom of the drivers door, what can i do to stop this from getting any further?
Rough up the surface of the flares with some 80 to 100 grit sand paper, use a good primer and then spray away.
As for the rust, grind it down to bare metal, bondo, prime and paint unless you are going to bedline the rockers. |
for the fenders, what is a good primer to use on the plastic surface?
for the rust, i have seen people use the bedliners all the way alone the rockers, what would it take to do that? is it worth it? |
With doing the bedliner on the flares I would do what AJBert said with sanding them but you wont need to use a primer. Wipe them down with prepsol or any other wax & grease remover, wipe off & go for it with the bedliner [this stuff is made to stick to anything].
As for the small amount of rust on your door, I would use some rust converter or nutraliser before putting on the bedliner. |
I agree, there is no need to prime if you're using bedliner. Just make sure the surface is clean first and you shouldn't have a problem!
Alright and hey if it doesn't work I can always sand it off and try again =p does everyone think it would look good to paint the rockers and fenders with the bedliner?
I've seen it done several times before. It's not really my style, but I don't mind it. It adds a certain ruggedness to the trucks
Sisk, you drive a darker colored truck, i think the black and red contrast very well together and thats what looks good =p but still its all a matter of opinion. For the prep work should i just sand the metal and the plastic down a bit to rough up the surface, then a good anti rust primer on the metal and paint away? thats what ive gathered lol
btw heres the areas i was thinking about painting....
http://i1005.photobucket.com/albums/...background.jpg |
You should remove the flares of your truck for a start[ saves alot of masking] give them a sand & wipe them down with a paint prep wax & degreaser then paint them.
As for the lower panels, where you have the small amount of rust use a rust converter or nutraliser [this isn't an anti rust primer as you already have the rust] Wipe your panels down with the wax & degreaser then wipe dry, mask of areas with a low tack masking tape & news paper [no need to sand these areas] & paint them. |
| All times are GMT -5. The time now is 01:08 PM. |
