-   Performance & Brainstorming (https://blazerforum.com/forum/performance-brainstorming-38/)
-   -   2.8 duramax swap? (https://blazerforum.com/forum/performance-brainstorming-38/2-8-duramax-swap-100070/)
03jawja 08-12-2019 05:54 AM
2.8 duramax swap?
What do you guys think about a 2.8 duramax in our platform? I feel like it would be the perfect swap! Good power, great fuel economy, decent aftermarket. I know I could go cheaper dropping a 5.3 in it or a newer 4.3 ecotec, but when you look at the stats it just looks like something to make it stand out
El_Beautor 08-12-2019 08:33 AM
It would be pretty cool but I suspect it would be a very expensive swap. Another diesel swap isCummins is now offering their 2.8L baby diesel as an aftermarket replacement kit (targeted primarily at Jeeps) but they're quite expensive. Very cool, but expensive.
03jawja 08-12-2019 09:32 AM
The duramax is cheaper than Cummins 2.8 repower. The dmax also makes alot more torque as well. It also has a bigger aftermarket
Hess13x 08-12-2019 10:14 PM
I would love to do a baby Duramax swap!
swartlkk 08-13-2019 06:10 AM
If your goal is to go diesel, a 4BT would likely be cheaper, easier to install, and more easily modded for all of the pros mentioned in the OP although they are heavy and not as refined.
03jawja 08-13-2019 06:15 AM
4bt is just sooo heavy, less efficient, and tall you'll need a body lift. Still good power though. Good aftermarket. Alot more info on swapping the 4bt
Tom A 08-13-2019 09:28 AM
What about one of those diesels out of a Nissan Titan? That would be a beast if it would fit.
03jawja 08-13-2019 10:40 AM
5.0 cummins would be nice, I know it would be much higher on the expense side. Little big, but you can make anything fit
03jawja 08-15-2019 09:08 AM
Has anybody considered the 2.7 turbo 4 that's in the silverado. It's not that great in the silvy..but out blazers weigh alot less. Good power..and mileage
