95 blazer gears
i have a 95 4.3 motor. its 4x4. what size gears come in the rear end? and what size can i change them to make my truck a little faster?
you have a 4x4, if you change one, you HAVE to change both. other wise the first time you put it in 4 wheel drive, either high or low, you will pretty much split your transfer case in half and cost yourself pounds of money. notice i wrote pounds of money.
so long as you know that, check this out. |
You can look at the RPO in your glove box to find which gear set your truck came with. There's 4 options for the S-series trucks:
- GU4 3.08 - GU6 3.42 - GT4 3.73 - GT5 4.10 |
