Axel swap for disk breaks
I was thinking of swaping a disk brake rear axel from a 4 door into my drum brake 2 door blazer.
Will this cause problems with the ABS? or the driveshaft? seems like it would work otherwise. |
I did it on my Blazer. Nothing special required. Just be sure to do a proper brake bleed afterwards and don't let the fluid reservoir run dry.
