axle swap
Would a 98 and up bravada axle fit 01 blazer?
Yes,just need to make sure the gears are the same.
Check the rpo codes in the glovebox. |
If I get one with 3.73 gears and mine has 3.42 gears will I have to change something I'm my computer to run 3.73?
You`ll have to change the gears in the front trans axle, thats all. find one with 3.42 gears
I think the shift points may be off going to 3.73, someone correct me if im wrong. It can be fixed by having the pcm tuned.
Not positive but dont think so, that has to do with rpm`s I believe
Good point, i know when i got my pcm tuned, he asked if i had stock gears or if i changed them, so i was thinking the pcm might need to know for some reason
guess it may be possible to change if wanted/needed
Originally Posted by newguy
(Post 588882)
Originally Posted by 01blazer16
(Post 588916)
why would I have to change gears in front if I have a 2wd truck?
| All times are GMT -5. The time now is 04:58 PM. |
