Comp Cams
What will be changed if I put comp cams in my truck?
cam change
Your exhaust gas ratio will change dramatically and the engine will not run correctly. Also, the MAF on the intake sensor will have to be re-calibrated, you would have to run 93 octane gas, change spark plugs to V-8 ones. Transmission would have to recalibrated. Power steering fluid would have to be changed to Dexron 6. Motor oil changed to 90W gear oil. Rally lots of changes needed
:icon_screwy::icon_verzsilly: |
Depends on the duration and lift and it has to be computer compatible.You have a roller cam its going to be very expensive to change it.If you have the $500 go for it.
| All times are GMT -5. The time now is 11:59 PM. |
