-   Performance & Brainstorming (https://blazerforum.com/forum/performance-brainstorming-38/)
-   -   Disc Brakes (https://blazerforum.com/forum/performance-brainstorming-38/disc-brakes-10887/)
viper4559 05-22-2007 10:18 PM
Disc Brakes
Hey all,
My dad has a friend in DC that said stay away from the drilled brakes because they will warp do to the rapid changes in temp. I was just curious what you all knew about the drilled/slotted disc brakes. I am currently planning on going with slotted discs and new pads and calipers when I get the money, but I wanted to know if it was worth it, or if I should just stay with the stock rotors?
Thanks,
Viper
swartlkk 05-22-2007 10:37 PM
RE: Disc Brakes
Slotted rotors have their benefits over stock flat rotors.
On the issue of drilled rotors, well, it all has to do with when the holes are put in the rotor. If they are drilled after casting, then the rotors are inherently weaker than stock and many have a tendancy to crack and come apart. Some have had decent luck with drilled rotors, but the fact that some have had catastrophic failures with them is enough to keep me from using them. And rotors that have cast in holes, which are much stronger, are just WAY too expensive and for our case, aren't even available.
viper4559 05-23-2007 08:22 PM
RE: Disc Brakes
But slotted rotors will be alright? No falling apart, no doing something bad that will cause me to die!?
drperry 05-25-2007 04:58 AM
RE: Disc Brakes
Slotted rotors will do ya great! Stick 'em with a good pair of pads and you'll be stoppin' on a dime, lad.
viper4559 05-25-2007 10:49 AM
RE: Disc Brakes
What are some good pads to look into? good brand names that is....
drperry 05-25-2007 03:13 PM
RE: Disc Brakes
As to that, I can't say... For my Z34 and S10, I bought bottom of the line cheap stuff (full set of rotors and pads for the Z34 was less than $100 Canadian, lol)
When the brakes are due on the Blazer, I'll be researching it...
Psychropod 07-19-2007 12:49 PM
RE: Disc Brakes
I like Bendix, myself. They last a long time and are built tough.
viper4559 07-19-2007 11:31 PM
RE: Disc Brakes
Well I ordered Power Stop slotted rotors and Hawk HPS pads for my front end back on the 8th of June from Cardomain.com, they still have not shipped or charged me. I called in earlier this week and the guy was supposed to call me back the next day with a time of expected departure. not real happy, but its the cheapest I could get all of it for, maybe even cheaper if they discount it for the problems :-)
TheBrettster 07-20-2007 03:01 AM
RE: Disc Brakes
Drilled also tend to crack.
