-   Performance & Brainstorming (https://blazerforum.com/forum/performance-brainstorming-38/)
-   -   Do throttle body spacers really help? (https://blazerforum.com/forum/performance-brainstorming-38/do-throttle-body-spacers-really-help-22595/)
Karcinagin 08-15-2008 09:51 PM
Do they ones with the helix on the inside to mix the air the fuel better?
and i might get a k&n cool air intake off my cousins s-10 he is selling (the truck) so would it be worth buying with having the intake? it cant make it worse can it.
swartlkk 08-15-2008 09:59 PM
RE: Do throttle body spacers really help?
Short answer, no, they really do not help the 4.3L engine.
A throttle body spacer works by increasing the volume of air in the intake plenum which effectively lowers the torque peak RPM, shifting the torque curve lower in the RPM range. This makes the engine feel more powerful off the line. Problem is, by shifting the torque curve lower also has a negative effect on the upper RPM horsepower due to increased friction in the intake path, a result of increased runner length.
On modern fuel injected vehicles, the results are negligible at best. With the 4.3L already having so much torque available off the line as well as running out of breath at the top end, a spacer will only hurt the top end even more.
dieseladdict90 09-08-2008 04:09 PM
i added a power-aid tb spacer to my 4.3ho and i feel that acceleration is stronger as well as smoother all the way through the rpm's. i also picked up 2 mpg's to get mine over 20.
davidstl25 12-17-2008 07:12 PM
i feel a good increase in the low end all the way thru to the red line and i noticed a huge difference in my MPG i think i get anywhere from 22 to 24 mpg on the highway
DdayK5 01-09-2009 01:09 PM
I have a poweraid spacer under my quadrajet on my 350 and I get 13 MPG around town.
Blazercrazy 03-02-2009 11:11 PM
lol Quadrabog. Should just find someone with a bucket to dump gas down there:D
95LS 03-03-2009 08:54 PM
quardajets can be a great carb IF ( this is a very big if ) they are set up right. id rather have a q-jet then a holley.
RWRIGHT 03-03-2009 09:41 PM
well my frined has the same blazer as me before he bought one he got 21 MPG after the TBS he now gets 26 MPG
TripleBlackBlazer 03-03-2009 09:49 PM
prove.it
OILCOUNTRY 03-03-2009 10:03 PM
I found with my Spacer I really didnt get any gains from it, other than the whistle and even thats isnt as loud as i have heard.... Quick stupid question here, If by some stupid chance I installed the stupid thing upside down would this explain my poor results?
