Electric fan upgrade worth the time?
Hello everyone! I'm been thinking about replacing my factory fan for an electric fan, I did it once before on my brothers Cherokee and it got really quite and had less wasted gas and a tiny bit more noticeable power as the fan isn't holding the engine and creating power restriction, yes there's a few modifications that needed to be done but it worked. Has anyone here done this? Any advise or results to share?
Ihave and was very happy with the results. Same you stated above
Originally Posted by newguy
(Post 653071)
Did you ran into any trouble or needed special modifications else than relays and coolant sensor? |
3 Attachment(s)
Living in hot Florida, it was one of the first things I did to my 04 when I got it. Intrepid/Sebring/Concord fans are easy to fit in. Hardest part is the wiring to be honest, and even that's not too difficult. Low speed on these fans is enough to keep the engine temp right at thermoset temp while idling on the hottest summer days with the AC on full blast :)
https://blazerforum.com/forum/attach...ine=1457394594 https://blazerforum.com/forum/attach...ine=1457394594 https://blazerforum.com/forum/attach...ine=1457394594 |
Its on my bucket list to do.
Did you ever wonder where the electric fans get THEIR power from?
Originally Posted by LeWhite
(Post 662553)
Automotive alternators do not control their electrical output by varying their mechanical load on the drivetrain. The mechanical load of the alternator on the drivetrain stay the same regardless of the power requirements of the vehicle, and the stock alternator is already making enough power to run an e-fan as long as you haven't added other power hungry systems like a big stereo. |
I believe someone here did it with an adapter between the temp sensor and the block
(Post 662629)
If only vehicles had an existing electrical system that would support an e-fan without needing any additional upgrades...
Automotive alternators do not control their electrical output by varying their mechanical load on the drivetrain. The mechanical load of the alternator on the drivetrain stay the same regardless of the power requirements of the vehicle, and the stock alternator is already making enough power to run an e-fan as long as you haven't added other power hungry systems like a big stereo. I'll admit the power draw curve from the stock fan to electric fans will be different, you will still need to produce the power somewhere. |
Agree with Above post, but a scrap yard d244 although and a new longer belt is fairly cheap.
| All times are GMT -5. The time now is 11:54 PM. |
