HP and Tourqe help?
I got an 02 4x4 blazer. I was wondering what some nice mods would be to increase torque and HP. I'm running disk brakes all the way around and I cant even roast my tires. Would it help to convert to drums in rear? Im just looking to increase the power, Its my toy and I wanna have fun with it! Would deleting the cat give it some hp? Im running a glasspack too. Would putting a proper muffler on increase it alot?
When I replaced my muffler with a glasspack I did not notice a gain or loss in power. I can hardly spin my tires right now but I could spin my old ones all day. I have no idea about the disk breaks because mine came with drums.
My old tires were pretty much bald though.. |
I have a 97 and have a hard time gettingthem not to break free.. everything's pretty much stock. 208000 miles even.regular maintenance only. But before I got it the throttle body mod was already done. If you haven't done this it does give some extra oomph.
Originally Posted by 4X4GS10B
(Post 590856)
check it on YouTube, it'll show you how to do it very easy to do.
(Post 590866)
I don't thank so, but you can pick them up at a junkyard pretty cheap and doit yourself.that's what I did to do my sons.
I'll give it a shot thanks.
That's what we all are here for brother, have fun.
Also would putting a bigger gear ratio in the rear help? Mines kinda shot anyway, i need to replace it but I dont know whether to go the same or bigger.
You could install a line lock. Maybe 4.10 gears with the stock size tires would make it spin tires off the line better.
just remember it being a four by four means whatever you to do the rear axle you must also do in the front one as well
I would definitely get rid of the pre-cat and the actual cat and replace the stock muffler/or in your case, Glasspack, with a chambered or straight through style muffler. You can go either single in single out or single in dual out. I would not run true duals... kinda over kill for a V6. Be sure to check emissions laws. AL doesn't do emissions testing but if you get pulled over and the officer is a pain he could write a hefty ticket. IMO no cats with a single in dual out flowmaster with 3 inch diameter 18 inch long exhaust tips ran striaght out the back sounds amazing. V8 sound at idle and only a slight whine/high pitch when you are getting on it. Also, a cold air intake will help a little with mid range torque. Don't expect to gain 30 ft lbs but it will make a little difference.. maybe 7-9 horse and 8-12 ft lbs torque. I have had 3 Blazers, just recently bought my 3rd and the exhaust is the biggest bolt-on/weld on performance gain you can get from these... you WILL pick up gas mileage if nothing else. 1-3 MPGs to be exact.
1. removal of cats is a violation of federal law
2. cold air intake give no improvement over stock which is already a cold air intake 3. its a blazer not a corvette...want more power spend more money, either build up the engine or swap it for something bigger |
Ok, maybe the cold air isn't so cold but you cannot tell me that a bigger intake tube with a more free flowing filter will not improve power and efficiency. The engine has more air readily available and does not have to "suck" as hard to get the same amount of air as it would if it had the stock intake. The engine can breathe better with mandrel bends and more free flowing filters. A stock intake is like having boogers in your nose in the morning versus a "Cold Air Intake" which is what your nose feels like after you blow that crap out. While it may take a dyno just to see the results of a cold air intake, it still doesn't change the fact that it will and does improve power at some part of the RPM range. As for the removal of cats... well it may be illegal federally, but my state does not check whether or not you are breaking the law and for all you know my blazer could be for off road use only. NASCAR race cars and Bigfoot don't have cats... I too agree its a Blazer and not a Corvette but at the same time bolts ons do improve efficiency. I have proven that with my Blazer 13.5 to 16 in town just by doing a CAI and a free flowing exhaust. I can't really tell too much of a difference as far as power goes but a imagine I gain at least 10 ponies somewhere in that power curve.
Seafoam!!! I just seafoamed my 95 CPI put half bottle in my oil and half in my fuel and can already see a power and fuel mileage increase. I have a CAI and no muffler just stock straight pipe and what I think is a resonator behind the y pipe I have no cat at all and my Blazer is as quiet as stock with no muffler. Next Seafoam I am gonna do is into the throttle body and I have been trying to find out where else to put it. Dies anyone know? I have been searching but no results.
I forgot to mention it is very easy to get the tires to spin on mine! Off the line and power braking it.
Originally Posted by coolasice
(Post 593186)
2. cold air intake give no improvement over stock which is already a cold air intake 3. its a blazer not a corvette...want more power spend more money, either build up the engine or swap it for something bigger ^ this. It already has a cold air intake from the factory. And if the new one does give any power, I doubt if it would be more than 5-8, and it would be so far up the power curve as to be unnoticeable. You can spend a ton on bolt-ons, and maybe make a few extra ponies, at the expense of torque. But if you are serious about power, you need to be thinking about camshafts, higher compression, even forced induction. Heck, build a 350 and put in if you really want to go fast. Speed costs money. How fast do you want to go? |
I wasn't talking about speed. I was just simply informing someone on ways to make a little extra power for a only a couple hundred bucks. I have less than $400 in my CAI and full exhaust. If you wanna go fast get turbo 4 cylinder with direct injection and 25lbs of boost...09 Cobalt SS turbo... or a dang a M series beemer. This discussion about what a cold air intake is and isn't and has been argued time and time again. Yea it may not be a means of getting the xoldest airnpossible but it is by far less restrictive thus having more air readily available for the engine to suck in. As for the exhaust... an aftermarket or custom welded exhaust is by far... a lot more less restrictive thus enabling the engine to more easily push exhuast gas out. The goal of every engine is to run as efficiently as possible by adding bolt ons you are helping it that much more.will bolt ons give you a hundred ponies no 50 nomaybe if you have a programmer or custom tune but still... i doubt it. I agree if you want a lot more power a cam and supporting parts (lifters, rockers, pushrods etc...) is the way to go or forced induction but those types of setups cost thousands. So if someone can spend a few hundred and get a sound they want while adding a little performance and a lot of efficiency.....
